dmontgo
Apr 27, 2020Tutor
Disabling Airtime Fairness (SONOS Support Recommendation) RAX75
Hello, Sonos was jumping between my wifi networks and now it won't connect at all to the Nighthawk router (hard wired through ethernet or otherwise). Sonos said that disabling airtim fairness is...
Christian_R
Apr 30, 2020NETGEAR Employee Retired
HI dmontgo,
Thanks for getting back. There is currently a newer firmware version available for the RAX75. May you update to the latest firmware version and we recommend performing a factory reset after updating your firmware.
https://kb.netgear.com/000061796/RAX75-Firmware-Version-1-0-2-76
Christian
dmontgo
Apr 30, 2020Tutor
Interesting- checking for firmware through the router said it was current. Done, updated... Still no Airtime fairness option
- Christian_RMay 01, 2020NETGEAR Employee Retired
Hi dmontgo,
Thanks for getting back. I was able to confirm with our product teams that the RAX75 currently does not support Airtime Fairness. I have requested for the user manual to be updated immediately.Thank you for understanding,
Christian
- dmontgoMay 01, 2020Tutor
Thanks. Can you confirm or deny that SONOS will work with this router? Thanks again
We have not received any reports of SONOS not being compatible with the RAX75. I would recommend contacting our support team for further investigation if your issues persists.
https://www.netgear.com/support/default.aspx
Christian
