temmet's avatar
temmet
DNS and Printer problems RAX80
Client OS: Windows 10 64 bit
Router: Nighthawk RAX80
Router firmware: V1.0.3.106_1.0.50
Purchase Date: 12/20/2020
Printer: Brother HL-L2380DW
I am ready to take a bat to this router and live in the woods.
I have a DNS problem that has existed since day one. Periodically, attempts to resolve a website will be very slow or outright fail. This happens to all devices, at times of high-use and low-use, regardless of how recently the request may have successfully resolved, and the device will maintain connection to the internet when it struggles to resolve a webpage. It gets weirder on the individual machines - Chrome may show a DNS error while Firefox loads the webpage without a problem, or vice versa. This happens inside applications with browsers, too, like Steam.
I have used static and alternate DNS configurations on the router as well as clients and the problem persists. I haven’t noticed a reduction in frequency. This problem went away if I used the old router. I don’t know what to do.
Now I have a printer that the router can detect but to which no client can connect. I’ve reconnected the printer to the network to ensure a fresh connection, reinstalled the printer software and drivers on the clients, but have had no success so far. While investigating this today, I noticed that none of the clients can ping each other but they can ping the router. Is there a setting in the router I’m missing?
Thanks, and please let me know what other information is needed to solve these problems.
    Is this a wifi connection from the printer to the router?
    The usual way to fix wifi printers is to find the printer maker's utility, the software that runs on your operating system. Then use that to connect the printer to the wifi.
    The router just broadcasts wifi. It is then down to the printer to play ball. There isn't much that you can do on a router, beyond fixing it to a particular IP address, that affects what the printer gets up to.
    Where possible, using the WPS feature can simplify things.
    Given the symptoms you describe, it might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
    The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
    • temmet's avatar
      temmet
      The printer software didn't detect the printer, but I was able to manually configure the IP address and it worked. I didn't use the Brother software with the last router so I assumed the same was true this time. Thank you very much.
      The modem is a Netgear CM600.
        Smells like a printer/PC issue. But I am not familiar with Brother printers.
        However, it make sense to me to at least trying to follow the maker's instructions before moving on to esoteric DNS tweaks.
        Nothing complicated to get in the way there.
