mrbart
Dec 07, 2018Aspirant
Dual Wan on the AX8 or AX12
ok heres my problem, i have 2 ISPs at home each with 1gb connections, i want to dual wan them. these new AX routers have one multi gig port, great. however, can the multigig port can only be used as ...
DarrenM
Dec 14, 2018Sr. NETGEAR Moderator
the Multi-Gig port is only available as a LAN port for the moment.
The option of using this Multi-Gig port as a WAN port may be implemented in the future
DarrenM
