mrbart
Dec 07, 2018Aspirant
Dual Wan on the AX8 or AX12
ok heres my problem, i have 2 ISPs at home each with 1gb connections, i want to dual wan them. these new AX routers have one multi gig port, great. however, can the multigig port can only be used as ...
mrbart
Dec 14, 2018Aspirant
ok perfect thats what i want, multigig LAN. is this for both models? so can i change one of the regular gigabit LAN ports into WAN? that way i can have dual gigabit WAN + multigig LAN
DarrenM
Dec 14, 2018Sr. NETGEAR Moderator
4 Ethernet ports: LAN (2 of them can be aggregate)
1 Ethernet port: WAN
1 Multi-Gig port: LAN
that is what is available on both units
One thing to keep in mind though is having the option to create a LAG from a RAX80/RAX120 to a modem does not mean that you can receive 2 different internet connections to the RAX80/RAX120.
It means that you can bond 2 Ethernet cables together between the ISP modem and the router in case you receive more than 1Gb on your internet connection and do not want to waste any bandwidth.
