daunois
Oct 12, 2021Aspirant
EAX80 « no internet connection »
Hi,
I’ve a strange situation with my EAX80. I’ve an extender deploy in Access Point mode, connected to my router with RJ45, and when I connect to admin interface, it told me that there is no internet connection.
The weird thing come from the fact that it is working well, I can connect to my local SSID and I can go to internet from my extender.
This is just the eax80 admin interface which told me « no internet connection ». ..
Does someone have an idea where it can com from ??
=> configured in access point
=> no single SSID as some component at home doesn’t support 5Ghz
Thanks
Thanks
1 Reply
What router are you connecting to?
What modem/gateway is the router connected to?
Is it causing an issue?
What firmware version are you on?
Smart connect doesn't need to be disabled if some devices don't have 5ghz. They just won't bandsteer to the 5ghz. You'd still be able to use it fine.
