bbbobbya10's avatar
bbbobbya10
Error 5478EH Model RAX35
Trying to intall router using app and when scanned it came up with Error  5478EH.Called support and said something about needed firewall but did not fully inderstand about this.Model RAX35 but this will not come in above window.
    • bbbobbya10's avatar
      bbbobbya10
      Not exactly sure on how to do that. Is it hooking the Ethernet cable directly from router to PC  bypass the modem .
      • plemans's avatar
        its not "bypassing" the modem.
        You connect your modem to the wan port on router.
        You connect a router lan port to a pc/laptop.
