Motorray's avatar
Oct 16, 2019
everyday my nighthawk ax 12 drops internet speeds to 20mbps
first 3 days called for tech support and everytime we just have to reboot the router
  • plemans's avatar
    Well a bit more info is needed.
    1. firmware on the router?
    2. What modem are you using?
    3. Is it happening over wireless and what band? Or is it happening over wired? Or both
    4. Is it happening to all devices or just one?
    5. Are you using QoS?
    6. What speeds do you pay for? What do you get hardwired to the modem? To the router?
    7. Did this happen with your old router at all?
    • Motorray's avatar
      Motorray
      Tutor
      firmware is v1.0.1.8_1.0.39 for RAX200
      modem is a cm1200
      yes both over the wireless and connected to wired
      yes all devices
      yes when login to the nighthawk routerlogin and with speedtest.net
      we pay for 300 and yes we have no problem with the old router and connected to the modem was just too slow
      • plemans's avatar
        I've noticed that the newer RAX devices firmware has been more beta than final version. I'd try reinstalling the firmware, factory resetting it, and starting back at stock. They seem to have issues whenever updates are done.
        If that doesnt help,you can try downgrading a version on the firmware.
