GChuck's avatar
GChuck
Get routers MAC addresses
I there any way within the Netgear Router web app to get the MAC addresses of the WAN, LAN and the three WLAN ports.  I've been using Linksys devices for years and this information was always available for each port.  I just like to keep a record of my "known" MACs for reference.
Thanks.
Greg
  • FURRYe38's avatar
    MAC addresses should be see on the routers web page under Advanced tab.
    • GChuck's avatar
      GChuck
      Thanks.
      I was hoping to be able to see ALL the interface MAC addresses.  I can see the WAN and LAN and the 2.4GHz wifi network, but cannot see the addresses for the 5GHz and 6GHz networks.
      My old Dlink 868L Wireless AC router just listed each network with associated addresses (*MAC and ethernet).
      I think I've figured them out by using Inssider.
      Greg
      • michaelkenward's avatar
        michaelkenward
        Attached devices?
        In the Basic menu for your device.
        If you see just an IP address and image, click the device.
        Among other ways.
