Elie973's avatar
Elie973
GHz 2 wifi completely disappeared since 1.0.3.106_1.0.58 version
I everybody i just installed the new 1.0.3.106_1.0.58 version and my 5GHz 2 wifi just disappeared, impossible to make it back even after a factory reset.
  • plemans's avatar
    what router do you have?
    You didn't put a model number.
    What gateway did you connect it to?
    • Elie973's avatar
      Elie973
      Sorry here is the infos
      NightHawk AX12 RAX200
      it's a Livebox 5 connected to it, after 20min the 5GHz 2 reappeared, i decided to reboot the rooter and it's has been appear about a 10min, before the update it hadn't never taken as long as this to apear.
      • plemans's avatar
        are you using smart connect?
        What are the led's on the router showing?
