items
Jan 25, 2021Aspirant
Guest network with Access point
Hi
My question is a bout setting up guest network while in AP mode.
I understand that AP mode is just passs through but any ideas if possible?
I have a main router and the RAX80 is connected to it as AP.
I have a guest network setup on the main router but I want to move it to the RAX80 and isolate the network ( stronger signal).
is it possible to define any kind of a VLAN on the RAX80 in AP mode that will seperate between the main network and the Guest nework?
> possible?The following router features are not available (grayed out) when
the router is in AP mode:o Guest Network
[...]On these routers, a "guest" network is not a separate network, but
there are firewall-like rules (enabled by default) which can limit the
ability of "guest" client devices to communicate with non-guest client
devices. (Those firewall-like rules are implemented in the router
section of the device, which is why that functionality is lost when the
router is configured as a wireless access point.)
> that will seperate between the main network and the Guest nework?I'm unaware of any such thing.
- itemsAspirant
Thanks
