JKonman
Aug 27, 2020Aspirant
HDD not showing
Have a Seagate 10tb hdd hooked upto my router I have readycloud setup and installed but the HDD isnt showing and I've tried the readycloud app on my phone and on windows and no use I have all the latest firmware and have checked all the settings and checked the forums for help and what i have found still wont show up.
Common problem are existing file systems on external USB storage devices. On larger capacity, a common default is exFAT these days - but that won't be recognized on the Netgear routers.
Re-format e.g. to NTFS while connected to a PC.
- JKonmanAspirant
File System is already NTFS whats adding to it may be my readycloud isnt connecting to my rounter it keeps saying that it's offline when i try to connect with it.
JKonman wrote:I have readycloud setup and installed but the HDD isnt showing and I've tried the readycloud app on my phone and on windows and no use
Start with the router Web interface and check the Advanced -> ReadyShare -> Advanced Settings if the default share is created, and the used and free space on the storage device is shown.
