akchcirn37
May 04, 2022Follower
Help Reflashing RAX45 Over TTL - No Reset Button, No Ethernet Ports
Need some technical advice here, please! Need advice on how to flash or reset the RAX45 using a TTL to serial connection.
Background...
- The latest firmware for the RAX45 (1.0.10) bricked my router.
- The ethernet ports are not recognized when plugged into a computer.
- The power button is solid white. Not flashing.
- The reset button is not working. Holding for 30 seconds does nothing. Holding, then power cycling does nothing.
I've got a serial connection going to the motherboard. TLL to serial is great. I can see the boot-up sequence using Putty...but cannot send commands from Putty to the router. I've tried forcing echo, and need some other ideas.
Background...
1 Reply
Sounds like the router is just dead. Something to contact NG support and see what your options are:
