foxxden12
Jun 28, 2020Aspirant
Help selecting new router
I'm looking at 2 different routers and am not tech savvy enough to know how they compare. One is the Nighthawk AX5400 (RAX50) which is WiFi 6. The other is the Nighthawk X10 AD7200 Smart WiFi route...
microchip8
Jun 28, 2020Master
Stay away from the R9000. It's dead technology (AD) and NETGEAR barely supports it any more. If you want a decent AC router, go for the R7800. For AX, I recommend the RAX120, though it's a bit expensive
foxxden12
Jun 29, 2020Aspirant
Thanks. I'm not wanting to spend $500, but what about the RAX50? My house is a single level, 2500 sqft home. The router is positioned near the middle of the house. Max of 15 devices connected at a time (couple of gaming consoles, smart TV, 4 phones, couple of laptops, Nest thermostat, garage door opener, water softener, refrigerator, Sonos speakers).
My internet provider is a wireless broadband and I have a 30 mbps download package. I typically get 31-35 download and 7-7.5 upload.
- Tofu-GolemJun 29, 2020ApprenticeI've never used the RAX50, but I was considering the RAX45 to replace the secondary (AP mode) router.
Speaking of which, maybe keep your old router around. If you can string am Ethernet cable between two different rooms, you can use your old router in AP mode to help cover dead spots.
