designgrrl
Jan 22, 2022Aspirant
Help with USB Device and ReadySHARE on RAX30
Hello helpful souls,
I am trying to attach a LaCie d2 Professional 8TB External Hard Drive to the USB port of my Nighthawk AX2400 RAX 30. (Links are to Amazon and will open in a new page.)
Following the directions in the manual, I formatted the drive to HFS+ using Disk Utility to select "Mac OS Extended (Journaled)". I named the drive "DATA".
When I attach "DATA" to the Nighthawk and select "Create Network Folder" in the ReadySHARE > USB Storage (Advanced Settings) GUI, I get a "No Disk" modal. When I access the drive from the "Network" location in the Mac OS Finder, I can see the drive and can access an "S_Drive" with a "share" folder already created; however, this "S_Drive" is only 206.5 MB (naturally defeating the purpose of offloading any media from my computers to an 8TB HD).
What am I doing wrong? Is this an issue with the 8 TB drive being too large? Do I need to create smaller partitions? Format the drive differently? I keep trying different options with the same results--the only thing I can access is a microscopic "S_Drive".
My goal is to store a couple TBs of photos and another 500GB of music on the drive for access on my home network.
Thanks for any help!
designgrrl wrote:
Could you tell me which 8TB Seagate drive you're using? Right now, I think I'd rather purchase something with at least one example of proven success than bang my head against the wall trying to get the LaCie to work.
Seagate Backup Plus Hub 8TB. STEL8000200.
This is in an R7800. It does not claim to be compatible with that router. It just works. I got it because it is listed as working with the R7000P. I have one of those too.
But this is suspicious:
So I decided to a 1TB Seagate Expansion Portable drive that I had lying around, since you mentioned success with Seagate. This showed promise, because I was able to use the "Create Network Folder" GUI. However, I still bumped. up against that ~200mb-sized "S_Drive" issue that I had with the LaCie.Is that what you got on the Mac? If so, it smells like something that has nothing to do with ReadySHARE.
You might want to see what they say over on the RAX world.
Oh dear, another USB problem. ReadySHARE technology is just a pain.
This is the first port of call for problems:
Solved: ALL Netgear USB Drive Mapping Issues ReadyShareCo... - NETGEAR Communities
We have had recent discussions here about which drives do and don't work with ReadySHARE. Some brands just don't seem, to play nicely.
Your router doesn't even feature in the compatibility list:
ReadySHARE USB Drives Compatibility List | Answer | NETGEAR Support
But that doesn'r seem to matter much, that list is so incomplete
The Lacie is also notably thin on drives listed there.
One recent victim ended up moving a drive between two different enclosures to get it to work.
The good news is that you can use 8TB drives. I do, but it is a Seagate drive. That even has two USB ports that ReadySHARE can see.
That can be a sign of a partitioned drive. ReadySHARE hates those.
And if a drive doesn't play nice with your operating system, I would put much hope in getting ReadySHARE to cooperate.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities- designgrrlAspirant
Thanks for all of this information, michaelkenward!
I tried a few things related to the information you shared and nothing seemed to improve the situation with the LaCie. So I decided to a 1TB Seagate Expansion Portable drive that I had lying around, since you mentioned success with Seagate. This showed promise, because I was able to use the "Create Network Folder" GUI. However, I still bumped. up against that ~200mb-sized "S_Drive" issue that I had with the LaCie.
Thanks again!
