morrismc's avatar
morrismc
how do I connect my internet coax to my Netgear Nighthawk Ax8
I purchased the Netgear Nighthawk Ax8 router with the intent to replace my internet provider's router. I want to cut the TV and Phone from my existing provider's plan and keep internet only. There is no coax port on the router to receive my cable for internet.  Is there an adapter to bring the coax cable to the ethernet port? Is that a good option or should I have chosen a different product that has a coax port? Thanks
  • plemans's avatar
    You don't say who your isp is but if you recieve internet service via coax you will need a modem. The RAX80 is a router only device (best route). You need a modem seperate. Or you can return the RAX80 and get a combo device that has a modem and router together. I'm not a fan of these as then the isp controls the firmware as well as if something goes wrong, you're out both devices.
    Who is your ISP? Usually they have a list of compatible modems based upon service you plan on using.
