aemilianvs
Mar 19, 2025Aspirant
How do I reset the VPN client certificates?
Hi community,
Anyone knows how can I reset the / create new VPN client certificates as the initial ones might have been compromised?
Thank you!
Which VPN is that?
Disclaimer: Just another user with time on their hands.
- aemilianvsAspirant
It's the VPN server of the router. I would need to regenerate the certificates that the server/router provides so that clients can connect using them.
- KitsapMaster
Do you use a Dynamic Domain Name Server (DDNS) service?
Whether you use a free or paid DDNS service, a user name, domain name, and password is required. These items are part of your VPN configuration in the router you set before generating the VPN files for the client device.
Go back to the DDNS service and change the password or better yet, create a whole new account with a new domain name and password.
Reconfigure your router VPN server and use the new DDNS information. Then create a new set of VPN configuration files for the client device. The old configuration files will no longer work with the new router configuration.
