Preesen
Jan 15, 2022Aspirant
How many devices can this router RAX40 connect to
What does this specs from Amazon website mean:
WIFI Coverage : 2,000 sq. ft., 20 devices
Does this mean the router can only connect to 20 devices in total?
- microchip8Master
20 devices per WiFi band
- PreesenAspirant
Thanks for the response.
Does that mean it can only connect to 40 Devices in total (2.4GHz and 5GHz) ?
That seems quite low considering the router provided by the ISP can do 64 devices.
I do know that it won't deliver the performance but just want to know the total number of device connections possible on this router.
- microchip8Master
Look up its manual on NETGEAR's site. It may mention how much
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.
