Neam
May 15, 2023Aspirant
How to completely stop automatic firmware update please.
Hi. I have newly purchased the NetGear Nighthawk RAZ120. It works well. I went into the settings and disabled the automatic firmware updates, but it still runs, and the firmware seems to be updated everyday. This is such a nuisance as I lost all connections every time. This is especially bad during office hours when I work from home and in conference meetings.
Why does it still runs even though I disabled the automatic update? Why are there so many firmware updates NetGear, come on? And most importantly, how do I stop this for good and only check when I want to update it please?
This is getting on nerves.
Thanks.
RAX120?
Should not be updating every day I believe.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
Then disable Automatic Updates?- NeamAspirant
Thanks FURRYe38 for your fast response. Much appreciated. my firmware version is "Router Firmware Version V1.2.8.40" and it is the latest version. I don't know the details of my modem, it is provided by my ISP Provider. It's a "NowTv Hub Two" Modem, which I connect to my NetGear router with a Cat5e cable. I can buy a new cable Cat6, but why would the issue be the cable?
It works fine, but once a day it does this "[Initialized, firmware version: V1.2.8.40] Monday, May 15, 2023 13:53:25", and when that happens, all connections are lost for a few minutes until it finishes. The "Disable automatic firmware update" doesn't work at all. Never had this issue before with any previous routers.
- microchip8MasterIt is not updating your firmware daily. That's not possible for multiple reasons. What it's doing is crashing and rebooting, hence the message you see about initialization and losing connection for a few minutes until it's fully up. There are multiple, lengthy threads on here about the RAX120 crashing/rebooting. Might try a forum search.
