Theo10mm's avatar
Theo10mm
How to Disable WPS on RAX50 Router (Part II)
I guess I struck a nerve with my last same topic and response because my thread was deleted/blocked/moderated. I am unable to access the thread. But anywho....
How to Disable WPS on RAX50 Router? There is nothing in the manual or online how to do it properly. There doesn't seem to be any way to do it at all for this particular router model.
A simple answer would be sufficient please. I don't need the extra "off-comments" either.
  • FURRYe38's avatar
    From what I see with my RAX50, there is no manual way of disabling of the WPS button. From what I understand though the service is idle only and only activates when the button is pressed. So someone has to phsycally press the button to do anything with WPS. Or if you disable the wifi radios on the router, this disables the WPS button and service as well.
