zhangs02000
Oct 01, 2022Follower
How to find R6700AX Router IMEI? It is NOT labeled on the router.
How to find R6700AX Router IMEI? It is NOT labeled on the router, as it usually do for other model. It might be in the packing box, but who keep the box?
imei is a mobile device identification number. What makes you think the R6700AX has one? Its not a mobile device
I scan and keep copies of the important details on boxes. Bit for most hardware it is also on a label on the device itself.
But as plemans says the box wouldn't be much help if you are looking for details that don't exist.
Are you connecting the router to a mobile modem/hotspot? That will have the IMEI you need to set up whatever that is on your network.
