kevanjosh's avatar
kevanjosh
Follower
Jul 17, 2023
How to get the most out of Nighthawk AX5400
Hey all. I'm a total noob to most of this stuff so please take it easy on me! But I did just purchase a wifi 6 router in the Nighthawk AX5400. My point of this post is to try and gather information to help me get the best performance out of this router. Unfortunately where I live 250mb is the best internet available to me, so that's what I have. I have it connected to my modem using a cat 8 ethernet cable. I've heard you can get better performance out of routers according to what channel you choose for your network? Or by changing the mghz or something? I live in a smaller town/neighborhood and when I search for networks in range there are probably only 3 to 4 neighbors networks that pop up. Thank you all in advance for your tips!
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Which one?
    AX5400  is not a unique Netgear model number. Many devices come with the AC/AX tag, but it is essentially a label that Netgear, and others, attach to hardware to describe wifi speeds.
    Look at the label on the device for the Model Number. And, if there is one, include the "V" bit to show the hardware version. If there is no V number, then you have V1.
    Start with the manual.
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    Heard where? The Internet is full of useless, misleading and often dangerous rubbish.
    In general it is a good idea to leave things alone until you have a problem that you want to fix.
