dabansotu
Sep 09, 2023Follower
How to get the most out of Nighthawk AX5400
Hey all. I'm a total noob to most of this stuff so please take it easy on me! But I did just purchase a wifi 6 router in the Nighthawk AX5400. My point of this post is to try and gather information...
michaelkenward
Sep 09, 2023Guru - Experienced User
dabansotu wrote:
But I did just purchase a wifi 6 router in the Nighthawk AX5400. My point of this post is to try and gather information to help me get the best performance out of this router.
plemans has given you sound advice,.
If you want to dog deeper, don't look for advice on what to do with an "AX5400". There is no such thing.
AX is not a Netgear model number. Many devices come with the AC/AX tag, but it is essentially a label that Netgear, and others, attach to hardware to describe wifi speeds.
Look at the label on the device for the Model Number. And, if there is one, include the "V" bit to show the hardware version. If there is no V number, then you have V1.
