NickEs
Mar 30, 2023Aspirant
How to set the RAX45 as a wireless repeater?
Hi, all. I have a new tri-band router as my main router (necessary because of MoCA), but the WiFi is not as strong as I'd like it to be -- so I'd like to set up my previous RAX45 as a repeater.
I've seen the directions at https://kb.netgear.com/24108/How-do-I-enable-the-extender-mode-feature-on-my-Nighthawk-router, but I think the directions show how to use the RAX45 as the main router and another router as the repeater (am I wrong?). I need to go in the other direction.
Can someone possibly help me out? Or correct me if I'm wrong about those directions?
- microchip8MasterRepeater mode is not supported by stock firmware.
What actual router do you have?
Why not look into just using an extender instead of trying to make a router work?
- KitsapMaster
If you have the option to run an Ethernet cable between your new router and the RAX45, then configure the RAX45 as an access point.
- NickEsAspirant
Yes, that was my backup plan. Here's what I've done:
1. Went into my Verizon router, and assigned the Nighthawk a static IP of 192.168.1.222 (via the MAC address).
2. Disconnected the Verizon router from the PC.
3. Connected the Nighthawk to the PC (using a Nighthawk LAN port, not the WAN)
4. Logged into the Nighthawk at 192.168.1.1.
5. Changed the SSIDs.
6. Under "LAN Setup," turned off dhcp.
7. Changed the router mode to "AP." While it was rebooting:
8. Disconnected the PC end of the cable and moved it to the Verizon LAN. The Verizon and Nighthawk are now connected, LAN to LAN.
It SEEMS to work. We'll see if it helps/
