Snopczynski
Feb 01, 2020Aspirant
How to setup Priority for Xbox one on RAX80 AX6000
Hi All, I am hard wired from my xbox one with cat 6 to a Netgear AX6000. I was wondering how to set the xbox one as the top priority device when it is on and being used? The xbox speed test is definitely faster when I disconnect some of the devices from the router. I play Call of Duty with a bunch of PC guys now, so i am trying to get the most I can out of the connection.
Thanks in advance.
- SnopczynskiAspirant
You guys alive? I figured out how to make my NAT open with the UpnP. Now I want to open up the Call of duty modern warfare channels full blast. Any help is appreciated.
- Christian_RNETGEAR Employee Retired
Hello Snopczynski,
You may also try enable dynamic QoS to optimize internet traffic management. Please refer to page 90 of the user manual linked below.
http://www.downloads.netgear.com/files/GDC/RAX80/RAX80_UM_EN.pdf
Christian
Do I want to enable the automatic QOS database update?
How do I give the Xbox one priority over everything else hooked to the router when the xbox one is turned on or being used?
Hello?
