rigram
Nov 16, 2025Aspirant
I can only make WiFi calls when I disable DoS and Port scan protection
Although this thread is closed - I have exactly the same problem as initially logged with WiFi calling. I can only make WiFi calls when I disable DoS and Port scan protection (I do however have Si...
Nov 17, 2025Guru - Experienced User
What mobile device are you using? Android or Apple?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/kb/en-home-nighthawk-knowledge-sharing/netgear-mobile-applications-and-androidapplewindows-devices-faq/2457045
- rigramNov 23, 2025Aspirant
The ISP modem is the NG one:
My Router: Nighthawk RAX80
Firmware: V1.0.10.140_1.0.79Device: Samsung ZFold 7 (Android)
Previously I had MAC Address randomize on - I have just now disabled it.
- FURRYe38Nov 24, 2025Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? The RAX is not a modem.
FW version is behind: https://kb.netgear.com/000070381
Might manually update the router and re-check this: https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
