jbuddy12's avatar
jbuddy12
I have a Netgear CM1100 and Nighthawk RAX75. Is there a compatible mesh system?
Is there a good mesh system compatible with my router? I don't want to buy another router to get the mesh?
Is there a less expensive option too as Nighthawk mesh is so expensive.
  • Any of them will work. but if if you're wanting ax then the EAX15, EAX20, EAX80 are all compatible.
    Otherwise I usually recommend the triband EX7500, EX7700, EX8000 line.
  • plemans's avatar
    Depending on how many satellites you need, there are mesh extenders.
    I don't usually recommend using more than 1 extender but you can do it.
    If you do, then I recommend a star configuration setup and not daisy chained.
    Daisy: router---->extender----->extender
    Star: Extender<-------router------->extender
    • jbuddy12's avatar
      jbuddy12
      Which mesh extenders work with my set up? Netgear has one that is $379.00 which is quite expensive. Had I known when I bought this, I would have gotten the Nighthawk mesh with the router all in one. Same dollars. Now I am piece mealing together it seems.
      • plemans's avatar
