jetsetser's avatar
jetsetser
Follower
Jun 02, 2020
i have the modem router c3000 , can i hook my nighthawk ax3000 to be the primary router?
trying to hook my night hawk ax3000 to my modem router combo netgear c3000. help!
  • plemans's avatar
    you can put the C3000 in modem only mode.
    This allows you to use the AX3000 as primary router.
    • michaelkenward's avatar
      michaelkenward
      If you visit the support pages:
      Support | NETGEAR
      you can feed in your model number and find the documentation for your hardware.
      Read the bit To cable your modem router to a router or gateway.
