bacin87's avatar
bacin87
Tutor
Aug 19, 2020
I have the RAX200 is the EAX80 the correct Extender for it?
I I have the RAX200 I have a older home that kills wifi will the EAX80 the correct Extender for it?
  • If you've got cat7 ran throughout the house and you're still within your return period on the RAX200, I'd return it and go with the orbi setup.
    Reason why is orbi has single ssid function with roaming. And it supports a wired and/or wireless backhaul.
    Versus the EAX80, when its hardwired in running in access point mode, doesn't function as a mesh device. It only functions as a mesh device in wireless extender mode.
  • plemans's avatar
     there's many extenders that would work. I'm a fan of the triband extenders (there isn't an AX triband extender yet).
    but the EAX80 would work with it. Would it work well in your home? Its tough to tell off the minimum info you gave. some older homes have plaster lathe walls or other materials that block wifi very well. I thats the case, sometimes its better to check into powerline devices, moca adapters, or even full mesh systems.
    What is your home made of?
    What size is it?
    • bacin87's avatar
      bacin87
      Tutor
      You're correct it is plaster lathe walls so for majority of the home I ran cat7. The house had knob and tube that's being replaced so powerline didn't work well after the rest of my house is rewired which will be done over the next two months I'll look at my power line adapter options.
      • plemans's avatar
