kimweselowski's avatar
Nov 25, 2020
I Phone 10 update
I phone 10 updated and now it won't connect to netgear wifi
  • plemans's avatar
    have you tried forgetting the network on your Iphone and re-doing the connection?
  • michaelkenward's avatar
    michaelkenward
    Nothing has changed at the router end.
    If the suggestion from plemans doesn't work, then you'll have to ask Apple for help. It  broke your phone. There's not much that Netgear can do about it.
