Corneileous
Jul 02, 2025Aspirant
Instructions for setting up nighthawk RAX41 to use with my ISP router in bridge or modem mode.
Just as the title states, I’m looking for advice on how I need to set this router up when I return it back to router mode that will be connected via ethernet cable to one of the outputs of my ISP pro...
Jul 03, 2025Guru - Experienced User
Yes. You can replace the ISP router with the NG router, if you want too. All up to you.
Corneileous
Jul 03, 2025Aspirant
Well, I think that’s exactly what I’m gonna do because after speaking with my ISP’s tier 2 technical support, they said I’d be better off just replacing their router with my own instead of putting theirs into bridge mode.
