Corneileous
Jul 02, 2025Aspirant
Instructions for setting up nighthawk RAX41 to use with my ISP router in bridge or modem mode.
Just as the title states, I’m looking for advice on how I need to set this router up when I return it back to router mode that will be connected via ethernet cable to one of the outputs of my ISP pro...
Jul 03, 2025Guru - Experienced User
No. Max you'll ever see over ethernet would be around 900Mpbs +-
Corneileous
Jul 03, 2025Aspirant
What about through WiFi? And able we're at it, what does it mean on the box when it says it can handle up to 3.45 GHz speeds?
