Ceebee1755
Jul 26, 2022Aspirant
Internet connection to caravan
I don't know much as will become evident and I think I may have brought the wrong thing..... I have a router AX2400 model RAX30 installed in a caravan. What do I need to get the internet?
I assume I also need a modem - what sort?
How do I install the Modem is it simply a case of plugging the Modem into the router.
Advice much appreciated. Thanks.
I
Yes these routers need a Modem or ONT of some sort to connect to work fully as intended.
Depends on what ISP you choose. Thats up to you.
Ask the perspective ISP on what they support in regards to modems or ONT and what can be connected to them.
- Ceebee1755Aspirant
Thanks.
Does the caravan have some sort of wired connection to the outside world and the telephone network?
If not you may have to investigate mobile telephone technology. Netgear makes a bunch of modems for those purposes.
Mobile Hotspots: 5G, 4G LTE | Portable WiFi Devices | NETGEAR
