Gene3222's avatar
Gene3222
Follower
Mar 31, 2023
Internet interrupts.
Will the Netgear AX6 timestamp and record any internet failures or interrupts?
  • FURRYe38's avatar
    What model NH router are you referring too? RAX or RAXE?
    I don't think NG reports any ISP outages. Rather may report a establish or re-establish of a connection on the WAN port.
    Something you can try your self by enabling the logging, then disconnect the LAN cable from the router for 5 seconds then plug back in then review the logs to see what it reports.
  • michaelkenward's avatar
    michaelkenward
    If you mean Internet interruptions, it logs those events here.
    Look for something like this:
    [admin login] from source 192.168.1.13, Wednesday, Jan 04,2023 19:58:58
    [Time synchronized with NTP server] Wednesday, Jan 04,2023 19:58:04
    [Internet connected] IP address: 217.43.151.249, Wednesday, Jan 04,2023 19:58:03
    [admin login] from source 192.168.1.13, Wednesday, Jan 04,2023 19:58:03
    [Internet disconnected] Wednesday, Jan 04,2023 19:57:51
    [admin login] from source 192.168.1.13, Wednesday, Jan 04,2023 19:57:50
    Thanks to my hopeless Internet service provider (BT in the UK), I am all too familiar with those entries.
    Not sure about your unnamed AX6, but I suspect that most Netgear routers do the same thing, My router is a Mesh WiFi 6 system that has to remain anonymous to protect the innocent.
