Hewvis
Feb 13, 2023Follower
internet way slow hardwired raxe300
internet plan is gig , when modem connected directly to comp get the speed when modem connected to the router then computer its down to 10mbps why ? , also nighthawk app cannot find the router
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.What mobile platform are you using for the NH app?
You sure the device IS connected wirelessly to the RAXE router?
1. what modem/gateway is the router connected to?
2. what firmware is on the router?
3. have you tried a different ethernet cable between router/computer?
4. have you logged into the router and checked its wan/lan connection page to see what speeds its connecting at?
https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
