cybot
Nov 10, 2022Luminary
IPv6 6to4 tunnel option broken? RAXE500
RAXE500 firmware V1.0.10.86_2.0.40
I am having trouble getting my IPv6 tunnel to work with my new RAXE500. the settings are all entered correctly, and when i use the 'ping -6 ipv6.google.com' command the command is able to retrieve the ipv6 address for ipv6.google.com, but both the server and client tunnel endpoints for the tunnel are timing out. I have even tried using anpth tunnel service, but the same issue occurs. test-ipv6.com gives the following results:
| Test with IPv4 DNS record | ok (0.213s) using ipv4 | |
| Test with IPv6 DNS record | timeout (15.014s) | |
| Test with Dual Stack DNS record | ok (0.615s) using ipv4 | |
| Test for Dual Stack DNS and large packet | ok (0.538s) using ipv4 | |
| Test IPv6 large packet | timeout (15.019s) | |
| Test if your ISP's DNS server uses IPv6 | ok (0.564s) using ipv4 | |
| Find IPv4 Service Provider | ok (0.644s) using ipv4 ASN 14051 | |
| Find IPv6 Service Provider | timeout (15.011s) |
I am not sure how to proceed next or what trouble shooting to perform next all i know, is the ipv6 traffic is going into the router, but it does not seem to be leaving it. The tunnel used to work, but has not worked with the new router.
Can you capture DEBUG logs, enable both debug and WAN to LAN captures before setting up the configuration, the after the configuration is setup, run your tests to check the configuration, then after save off the logs.
