JohnDiV
Jul 03, 2020Star
IPV6 on RAX200 router not working after 1.0.2.88 and 1.0.2.92 Update
IPV6 on RAX200 router not working after 1.0.2.88 or 1.0.2.92 Updates. This router is connected to the Netgear CM-1150 Modem. My provider is Comcast. Had to roll back to a previous 1.0.2.8 firmware update. I spoke with Netgear 3 weeks ago and they are aware of this issue. By now I would have thought they would have released a fix with the current firmware update of 1.0.2.92, but as always they are slow to fix. I am disappointed with their Software Quality Control. This is my last Netgear product. Big bucks for RAX200, Not worth the money when there is slow support for their most expensive routers. All my older cheaper Netgear routers have no problem with IPV6. Netgear you are going backwards.
Still waiting for the fix!!
- Christian_RNETGEAR Employee Retired
Hello JohnDiV,
I may have a trial firmware that may help resolve your issue. If you're interested, please send me a private message with your email address and serial number.
Christian
- William3087AspirantHaving same problem the entire firmware is broken even the Bitdefender security
- rinthosLuminary
Christian_R wrote:Hello JohnDiV,
Christian
+1 to Christian_R's offer. If you're blocked due to IPv6, his trial firmware version seems to do the trick, at least verified w/ DHCP-based IPv6 (such as most Comcast and Xfinity plans). Seems specifically just for this issue I believe...
Thanks for helping Christian!
- RajaDajaLuminary
Hey Christian_R,
Please send this firmware, I need it again, lost the previous one you sent me. Thanks
Thank You Christian !
- SeanWangTaiwanAspirant
Now is 2020/09/18
I still cannot use ipv6 on netgear rax200.
The last release firmware still stuck at v1.0.2.92_1.0.50.
I'm also still waiting this stupid issue be solved for along time.
this is my first to bought netgear product and I think is last time.
it's not worth 579.59 USD.
terrible UI/UX and after service.Yes, the router is garbage. Netgear has no clue when it comes to AX. I will end up selling mine for a loss. I have gone back to AC for now, I bought the Deco M9 Plus from Costco. Mesh wifi is not for everyone but the system has been rock solid for me. I also put DD-Wrt on my older Netgear and bridged it on the 5ghz and set the 2.4 in ap mode to make the transfer of my 2.4 devices to the mesh single ssid a breeze
Hi SeanWangTaiwan & Imanpunk,
I currently have a trial firmware available for the RAX200 that may help with your issues. If you're interested, send me a private message with your email address and serial number.
Christian
No thanks, I have moved on from Netgear. The RAX200 is a $600 paperweight. Netgear used to be good
