motion4life
May 10, 2023Aspirant
IPv6 Port forwarding
I see the options to enable ipv6, but i don't see anything about port forwarding with ipv6. i'm trying to setup my server to be able to use ipv4 and ipv6.
Any help would be appreciated. Thanks!
- microchip8MasterThere is no NAT in IPv6. The address you get is a public one, so there is no NAT and no need for port forwarding.
- motion4lifeAspirant
do i need to enable ipv6 on the router then? what option should i select so that it can be open?
Disabled
Auto Detect
6to4 Tunnel
Pass Through
Fixed
DHCP
PPPoE
Auto Config
6rd
- microchip8MasterIf you want an IPv6 address, of course you have to enable IPv6. Start with "Auto Detect".
Do note that the router has an IPv6 firewall that can't be configured by the user. So if you need to open a port for a server, you won't be able to on router level.
