betens's avatar
betens
Follower
Apr 27, 2022
Is the Netgear Nighthawk RAX50 worth it?
The Nighthawk is currently at a fairly good discount at my local store, it has good reviews, but when looking it up on Reddit, there were a few posts stating that the router is "unstable". I.e dropping out, needing to factory reset after each firmware upgrade and low speeds etc.
I currently have the Asus rt-ac66u, but I'm not happy with it. Installing merlin did not solve my issues either. I consistently need to restart it at least once a day due to internet dropouts
So is the nighthawk a good router, and is it stable would be my question?
  • plemans's avatar
    You'll always see posts with people that have issues. They're always going to go on support forums/review sites to explain the issues you're having. So you'll never find something that has 100% good reviews.
    I usually recommend to people to buy from a site/store that has a good return policy. Buy the device and give it a good week and if its not to your satisfaction. return it. Usually you can tell pretty quickly if something meets your needs or not.
    • michaelkenward's avatar
      michaelkenward
      Very true. This place attracts people with problems, not those with success stores to report.
      Another place to look for views is on the sellers' sites/No one would ever trust Amazon, say, as the ultimate arbiter, but people will write reviews for things that they like as well as stuff that cause problems.
