OhbewanX1
Feb 19, 2019Aspirant
Is there a way to get RAX80 to send log entries to a central log server?
Is there a way to send RAX80 log messages to a central server? I am currently emailing the logs but then have to post process to extract the data.
- Feb 21, 2019
Someone may have a way to do that but the router itself will only send the email logs.
DarrenM
DarrenM
Feb 21, 2019Sr. NETGEAR Moderator
DarrenM
- OhbewanX1Feb 25, 2019Aspirant
I have two RAX80's in two sites. Both are showing DOS attacks in the logs although not at a rate which causes any issue. However, since the scans are there I feel I need to keep an eye on them. Having them stored automaticly would make this a semi-automatic task since they would then be in a data base which could be sorted and scanned easily. Also, logs get cleared by crashes and reboots so sending to the log server preserves them for debug. The routers I replaced had this feature which I used routinely.
I hope this feature gets put in the RAX80 in a future firmware upgrade.
