Mdhedd94's avatar
Mdhedd94
Follower
Oct 20, 2021
Mesh WiFi 6 Router(MR60)
I bought a Netgear Nighthawk mesh router today. Everything (phones, laptops, streaming TV) all connect, but not Skylight frame.
  • plemans's avatar
    1. what modem/gateway are you connected to?
    2. what is a skylight frame? Did you contact them for help setting up?
    3. did you use the same ssid as your old router so devices would just auto-connect? Or did you change ssid/password?
  • FURRYe38's avatar
    Netgear has set up a community forum specifically for the NightHawk MESH products. Most of the people who watch that forum are more likely to have experience with NH MESH products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Nighthawk-Mesh-System/bd-p/en-home-nighthawk-mesh-system
    Thank you.
