chipforex101
Apr 08, 2026Aspirant
model CAX30 Netflix will not connect
Hello, Looking to see if there are any reported issues with nighthawk router after a power interruption . Seems Something is not allowing it to load Netflix. Keep getting connection failed code...
chipforex101
Apr 10, 2026Aspirant
Hello, Yes it always shows good when i have this issue. All other devices work fine but it seems my sony bravia tv with netflix installed has a problem re-connecting? This can go on for 2 days. I also reboot router and tv but it takes several tries. even then I have to wait till the next day , then it will connect to netflix. My tv says its a network connection issue. I should have taken a picture of the code that Netflix displays. Cant remember it. .
Apr 11, 2026Guru - Experienced User
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
https://kb.netgear.com/23783/How-do-I-change-the-wireless-channel-on-my-NETGEAR-router
Please post a copy and paste of the modems connection status and event log page.
- chipforex101Apr 11, 2026Aspirant
Hello,
Ok will check those channels now. Curious what they are set too. Will attach copies i Took. Hope this is what you want.
