chipforex101
Apr 08, 2026Aspirant
model CAX30 Netflix will not connect
Hello, Looking to see if there are any reported issues with nighthawk router after a power interruption . Seems Something is not allowing it to load Netflix. Keep getting connection failed code...
chipforex101
Apr 11, 2026Aspirant
Netflix works on other devices, just issues on tv saying network connection issue while displaying internet connected. When i do diagnostics it says wi fi not connected. So something causes the connection to not fully work with netflix until it clears itself somehow.
Does netflix not load on any device? Just sony Bravia TV
How long was the power interruption? Unknown happened overnight
Devices wireless or ethernet or both connected to the gateway? Wireless only
- StephenBApr 11, 2026Guru - Experienced User
chipforex101 wrote:
Just sony Bravia TV
Try setting up a guest network, and connecting the Bravia to that network. Start with 5 ghz, if that doesn't work well then switch over to 2.4 ghz.
