roger159
Jun 02, 2024Aspirant
Modem issue
Hi all, I'm having issues setting up my TalkTalk D-link DSL-3782 router as a modem only. I have turned off wifi and DHCP on the D-Link but cannot get internet via wifi or ethernet after setting up my Netgear AX1800 RAX10.
Any help gratefully received.
Roger159.
Try this:
d-link dsl-3782 bridge mode - Google Search
And:
User Manual D-Link https://www.dlink.com › dsl › dsl-3782 › manual
- roger159Aspirant
Thank you Michael, I'll check your links out.
Good luck. DSL modem-only devices are getting hard to come by. Netgear got out of that market a few years ago. And many ISP modem/router boxes (think BT) do not support bridge mode.
There are other options, albeit more complicated. So come back if it doesn't work.
This might also help.
How to fix issues with Double NAT | Answer | NETGEAR Support
