Jaime10's avatar
Jaime10
Tutor
May 24, 2021
MR60 Mesh Nighthawk how many devices can I connect?
I recently purchased this router. I read that you can connect 25 devices. I currently have 14 devices and plan to add the Ring alarm system which will add another 20 devices. I wonder if having 45 devices connected will degrade the speed of the system. I wonder if anybody have any experience with similar situation. Thanks in advance.
    • Jaime10's avatar
      Jaime10
      Tutor
      Thanks for the quick response. I looked at the link you sent me but I do not see the MR60 model listed in the list showing "This article applies to:
      Not sure if it goes by a different model number or if it is a new model and the list has not been updated by Netgear. Should I assume that it also applies to my model?
      Thanks again for your help.
      • plemans's avatar
        That list hasn't been updated since 2016.
        I'd doubt that your device supports less than the older devices but anything is possible :)
