Vector77
Dec 29, 2020Aspirant
MS60 satelites will not sync with MR60 router
I have the Nighthawk Mesh WiFi 6 System in my home. It was working fine until about 3 days ago. Now the MR60 router will not sync with the 2 satellites (MS60). I have gone through the process of pushing the sync buttons on both devices. It appears that they are syncing and the LED on both the router and satellites turns blue. According to the manual, they should be synced up, but they aren't. When I go into the Nighthawk app on my iPad and select Network Map, the 2 satellites show a purple dot next to them instead of the green dot. Also, when I select one of the satellites, I go to a page that says "No Connected Device Found."
Any suggestions would be greatly appreciated.
- Christian_RNETGEAR Employee Retired
Hello Vector77,
You may try performing a factory reset on your Nighthawk Mesh system and running through the setup assistant again using the Nighthawk app.
Christian
- Vector77Aspirant
Thank you, Christian, but I have already tried the reset suggestion and it made no difference.
Hi Vector77,
I would recommend contacting our support team for further assistance to investigate whether this may be due to hardware.
https://www.netgear.com/support/contact.aspx
Christian
