pjd813
Aug 03, 2022Guide
My AX6000 simply does not work.
Does the AX-11000 suffer the same problem of constantly dropping connectivity over both WiFI and Ethernet? My AX6000 worked fine for two weeks and has been getting progressively worse over the last 4 or 5 weeks. I’m getting a refund from Amazon and now I am looking for a better alternative. The number of reviews that say that these either arrived DOA or stopped being stable have multiplied over the last two months.
What actual device do you have? AX6000 is a speed.
It could be you had a bad device.
I'd highly recommend looking through the reviews (not just the forums because thats where people with issues come) to see how well they last long term.
- pjd813Guide
Hi,
Here is a better model # description. I have the RAX-120 and it does not maintain an internet connection at all anymore. The more recent reviews are almost uniformly terrible.
My question is about the RAX-200….. does anyone here know if it has the same issue?
I've got an RAX200 and when I used it, it worked great. I upgraded to the RAXE500 and then the RBKE963 so I haven't used mine in a bit but again, it worked well when I had it.
