Boombar
Mar 06, 2019Tutor
My laptop doesnt see my Nighthawk AX8 with AX WiFi enabled
One of my laptops doesnt see the router with AX WiFi setting on.
After i disable it it does see it.
Any suggestions of a workaround on either end?
What am i missing if i turn off the AX WiFi?
schumaku
Jun 10, 2019Guru - Experienced User
Your Windows 10 Inhell wireless drivers require an update - even what the vendors like Dell are offering is often not up2date, and older 802.11ac drivers fail to connect to radios with 802.11ax support -> Intel® Driver and Support Assistant (Intel® DSA)
TomPoz
Jun 10, 2019Initiate
Thank you for the info. Updating the wi-fi driver resolved the issue.
