vijayeee87
Aug 22, 2022Aspirant
My WiFi Router
After prolonged ISP side network issue or after night hours, the WiFi connection is not resuming. I checked the status of internet connection in Router it is good. But, the DHCP clients are not conne...
michaelkenward
Aug 22, 2022Guru - Experienced User
vijayeee87 wrote:
I had to reset the router and perform all the settings from the very beginning and then it works. But, cannot perform this kind of troubleshooting every or alternate days.
You can shorten that process greatly by saving the configuration of your router along with all of those settings and the reloading it after you have reset the device.
You should do that even if the thing doesn't need these daily resets.
