vijayeee87
Aug 22, 2022Aspirant
My WiFi Router
After prolonged ISP side network issue or after night hours, the WiFi connection is not resuming. I checked the status of internet connection in Router it is good. But, the DHCP clients are not conne...
Aug 22, 2022Guru - Experienced User
What router do you have?
What firmware is on it?
what modem/gateway is it connected to?
Do all device have issues or just wireless?
vijayeee87
What router do you have? - AX3000 WiFi Router (RAX40)
What firmware is on it? - Firmware Version V1.0.4.102_1.0.1
what modem/gateway is it connected to? - The router itself is configured as a modem to connect to ISP network (PPOE)
Do all device have issues or just wireless? - All the clients in the LAN are experiencing issues.
- michaelkenwardAug 22, 2022Guru - Experienced User
You will have to explain that. The RAX40 is not a modem. As a router it needs something between itself and the Internet to work.
This will usually be a cable modem, sometimes a DSL modem, or increasingly an Optical Network Terminator (ONT). (Let's not worry about exotic satellite systems at this stage.)
Anything else is likely to come out of a "hole in the wall" that has a router at the other end. If that is what you have, then your configuration will have to reflect that.
The PPPoE bit is something that you feed into the router to get the connection through the modem.
