TorwaK
Oct 03, 2019Aspirant
NAT loopback and SNMP reads
Hi all,
Can you please let me know if NETGEAR Nighthawk AX12 12-Stream Wifi 6 Router-RAX120 supports NAT loopback feature and SNMP reads for mrtg readings?
Thanks!
TorwaK wrote:The article has been updated on 2018. So it would be great if someone ... confirms AX12 is featuring NAT Loopback functionality.
TorwaK wrote:Can you please let me know if NETGEAR Nighthawk AX12 12-Stream Wifi 6 Router-RAX120 supports NAT loopback feature
NETGEAR Router support for NAT Loopback Note: The text list is incomplete, check the "This article applies to: " ChristineT please ensure the KB entry will be updated.
TorwaK wrote:SNMP reads for mrtg readings?
There is no SNMP on Netgear consumer routers available.
- TorwaKAspirant
Thanks for the reply.
The article has been updated on 2018. So it would be great if someone from the support team confirms AX12 is featuring NAT Loopback functionality.
